[GRASS-user] importing dem files: projection details?
Tyler Smith tyler.smith at eku.edu
Sun Mar 14 01:19:13 EST 2010
It's been a while since I used GRASS, and I'm having trouble getting my
data into the system. The data I'm working on is available here:
http://kymartian.ky.gov/demwebusgs/har/index.html
It's USGS format DEM data. The meta data is found here:
http://kymartian.ky.gov/demwebusgs/DEM_dem.xml
Apparently, the metadata is not available in the data files, so I had to
enter the details by hand in setting up a new location. I'm working from
Neteler and Mitasova 3rd ed., but otherwise have very limited GIS
background. My attempt at the projection is listed below. It appears
that I'm using two different systems here, with the actual raster file
in units of meters, while the default region is measured in degrees. I'm
not sure how to convert the easting/northing into degrees, or the
degrees into meters. I've also tried this with State Plane System and
Lat-Long, but haven't figured out what I'm doing wrong. Please help!
Thanks,
Tyler
-PROJ_INFO-------------------------------------------------
name       : Lambert Conformal Conic
datum      : nad83
nadgrids   : TN
proj       : lcc
ellps      : grs80
a          : 6378137.0000000000
es         : 0.0066943800
f          : 298.2572221010
lat_0      : 36.3333333300
lat_1      : 38.6666666670
lat_2      : 37.0833333330
lon_0      : -85.7500000000
x_0        : 1500000.0000000000
y_0        : 1000000.0000000000
-PROJ_UNITS------------------------------------------------
unit       : meter
units      : meters
meters     : 1.0
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20100314/d86fc71a/tyler_smith.vcf
