[GRASS-user] importing dem files: projection details?
Tyler Smith tyler.smith at eku.edu
Mon Mar 15 08:35:45 EDT 2010
On 03/15/2010 03:42 AM, Markus Neteler wrote:
> The rule is that you can have only one projection in a location.
> If you have several projections you need several locations and
> to reproject data between them (r.proj, v.proj).
> GRASS can generate locations directly from metadata.
So far, I've failed to convince GRASS to do anything directly.
Trying the auto route:
grass64 -gui
select define new location with georeferenced file
select the dem file: k42.dem
select the TN transformation, as probably better than the default for
adjacent Kentucky
enter GRASS with the newly created location and the PERMANENT mapset
Results in this error:
"g.proj or projection error: ERROR: default region is invalid
     line 3: <north: 1080:43:46N>"
So GRASS has automatically set up the location using degrees, and then
get confused when the raster co-ordinates are provided in meters. Which
appears to be fairly close to the sort of problem I ran into when
setting this up manually. What am I missing?
Thanks,
Tyler
> Cheers
> Markus
>> Thanks,
>> Tyler
>> -PROJ_INFO-------------------------------------------------
>> name       : Lambert Conformal Conic
>> datum      : nad83
>> nadgrids   : TN
>> proj       : lcc
>> ellps      : grs80
>> a          : 6378137.0000000000
>> es         : 0.0066943800
>> f          : 298.2572221010
>> lat_0      : 36.3333333300
>> lat_1      : 38.6666666670
>> lat_2      : 37.0833333330
>> lon_0      : -85.7500000000
>> x_0        : 1500000.0000000000
>> y_0        : 1000000.0000000000
>> -PROJ_UNITS------------------------------------------------
>> unit       : meter
>> units      : meters
>> meters     : 1.0
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20100315/a04f9753/tyler_smith.vcf
