[GRASS-user] sum one raster map conditional on another raster map
Martin Wegmann
martin.wegmann at uni-wuerzburg.de
Thu Mar 18 09:07:02 EDT 2010
Hello Stephen,
On Mittwoch, 17. März 2010 23:06:55 stephen sefick wrote:
> I would like to sum all of the positive values of one raster map
> (NDVI) based on a raster containing many watersheds that have values
> 1-22. Is there a way to do this in GRASS? Or a way to export this
Glynn already pointed you to r.statistics hence you only need to combine it
with a few if-else statement in r.mapcalc:
r.mapcalc "watershed_new = if(watershed >=1 && watershed <=22,1,0)"
# if watersheds values are larger-equal 1 AND smaller-equal 22, assign value 1
otherwise value 0
r.mapcalc "ndvi_new = if(ndvi_raster >=0,ndvi_raster,null())"
#all values above 0 keep their values, below 0 are converted to null()
(nothing)
r.mapcalc "ndvi_new_clip = if(watershed_new == 1,ndvi_new,null())"
# if watershed_new is equal 1 (see above), then assign the values of ndvi_new,
otherwise nothing
now you can perform the r.statistics method=sum analysis on NDVI values above
0 only and for areas where watershed is above 1 and below 22.
hope this helps and I understood your question right, Martin
P.S.: in case you want to do the analysis on single watersheds (1-22) then you
would need another statement like:
for i in 1 2 3 4 5 ... 22 ; do
r.mapcalc "new = if(watershed == $i,1,null())"
r.statistics ....
; done
Dr. Martin Wegmann
University of Wuerzburg
Institute of Geography
Department of Remote Sensing
Remote Sensing and Ecosystem Research
Am Hubland
97074 Wuerzburg, Germany
German Aerospace Center (DLR)
German Remote Sensing Data Center (DFD)
Phone: +49-(0)931-31-83446
Fax: +49-(0)931-888-4961
Email: martin.wegmann at uni-wuerzburg.de
url: http://www.remote-sensing.uni-wuerzburg.de
url: http://www.dlr.de/caf
url: http://www.global-change-ecology.de
