[GRASS-user] make command (install add on)
    schorschli
    matthiasoswald at hotmail.com
    Fri Mar 19 12:29:40 EDT 2010
I want to test the interesting net.analyze addons (mostly because of
v.net.distance). I've downloaded it but now not able to install it... :-(
Following the instruction first I changed the directory to the path where
the downloaded addons are saved:
cd Documents/temp/net.analyze
Then I tried the make command:
make MODULE_TOPDIR=/Applications/GRASS-6.4.app/Contents/MacOS/
As a result I get the an error:
make: *** Makefile: Is a directory.  Stop.
Does someone know what this could mean and what I'm doing wrong?
Tusend tack,
schorschli
View this message in context: http://n2.nabble.com/make-command-install-add-on-tp4764072p4764072.html
Sent from the Grass - Users mailing list archive at Nabble.com.
