[GRASS-user] Re: importing dem files: projection details?
Tyler Smith
tyler.smith at eku.edu
Sat Mar 20 20:43:15 EDT 2010
Tyler Smith <tyler.smith at eku.edu> writes:
>> Please post the output of gdalinfo on that file. GRASS uses GDAL to detect
>> projections from metadata.
I'm still having trouble processing the following file. Any help would
be great.
Thanks again,
Tyler
> gdalinfo k42.dem
> Driver: USGSDEM/USGS Optional ASCII DEM (and CDED)
> Files: k42.dem
> Size is 1222, 1535
> Coordinate System is:
> GEOGCS["NAD83",
> DATUM["North_American_Datum_1983",
> SPHEROID["GRS 1980",6378137,298.257222101,
> AUTHORITY["EPSG","7019"]],
> TOWGS84[0,0,0,0,0,0,0],
> AUTHORITY["EPSG","6269"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9108"]],
> AUTHORITY["EPSG","4269"]]
> Origin = (1467.054166666666561,1080.729444444444425)
> Pixel Size = (0.008333333333333,-0.008333333333333)
> Metadata:
> AREA_OR_POINT=Point
> Corner Coordinates:
> Upper Left ( 1467.054, 1080.729)
> Lower Left ( 1467.054, 1067.938)
> Upper Right ( 1477.237, 1080.729)
> Lower Right ( 1477.237, 1067.938)
> Center ( 1472.146, 1074.334)
> Band 1 Block=1222x1535 Type=Float32, ColorInterp=Undefined
> NoData Value=-32767
> Unit Type: ft
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
