[GRASS-user] problems with GRASS 6.4
José Miguel Barrios jmbarriosg at gmail.com
Tue Mar 23 04:58:35 EDT 2010
Hello list;
I have just installed the new Grass version but I haven't been able to work
with it!
If I try to launch the GRASS 6.4 ORC6 with the new wxpython GUI; I get an
error message saying that python.exe has detected a problem and has to
close.  Further, I get this:
ERROR: G_getenv(): Variable LOCATION_NAME not set
  File "C:/Archivos de programa/GRASS-64/etc/wxpython/gis_set.py", line 866,
in
<module>
    GRASSStartUp = StartUp(0)
  File
"C:\OSGeo4W\apps\Python25\lib\site-packages\wx-2.8-msw-unicode\wx\_core.p
y", line 7935, in __init__
    self._BootstrapApp()
  File
y", line 7509, in _BootstrapApp
    return _core_.PyApp__BootstrapApp(*args, **kwargs)
  File "C:/Archivos de programa/GRASS-64/etc/wxpython/gis_set.py", line 837,
in
OnInit
    StartUp = GRASSStartup()
  File "C:/Archivos de programa/GRASS-64/etc/wxpython/gis_set.py", line 165,
in
__init__
    self._set_properties()
  File "C:/Archivos de programa/GRASS-64/etc/wxpython/gis_set.py", line 215,
in
_set_properties
    not os.path.isdir(os.path.join(self.gisdbase, location)):
  File "C:\Archivos de programa\GRASS-64\Python25\lib\ntpath.py", line 67,
in jo
in
    elif isabs(b):
  File "C:\Archivos de programa\GRASS-64\Python25\lib\ntpath.py", line 53,
in is
abs
    s = splitdrive(s)[1]
  File "C:\Archivos de programa\GRASS-64\Python25\lib\ntpath.py", line 119,
in s
plitdrive
    if p[1:2] == ':':
TypeError: 'NoneType' object is unsubscriptable
If I try to use the very nice GRASS 6.4 ORC6 with MSYS interface; the
computer gets blocked if I try to run a command.
Any idea of what the problem could be?
Thank you in advance
Miguel
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100323/64349e02/attachment-0001.html
