[GRASS-user] Large File Support (LFS)
John Tate
john.tate at ntlworld.com
Tue Mar 23 07:57:15 EDT 2010
Hamish wrote:
> if you have a 32bit machine, the solution/workaround for this is
> to pipe from stdin instead. try this:
> cat /home/bob2/rawdata/clean/test4.asc | r.in.xyz input=- \
> output=test4 method=min fs=, x=6 y=7 z=8
> or this:
> r.in.xyz input=- output=test4 method=min fs=, x=6 y=7 z=8 < \
> > and <2Gb files start to process fine (without -s flag)(didn't continue
> > processing, to save time in testing), but >2Gb give the same
> > message: 'Unable to open input file...'
> try sending the data via stdin rather than reading the file
> directly, as in the examples above.
Nice one, cheers. That solves the challenge.
> > I compiled and installed yesterday (20/03/10) following the
> > specific Ubuntu page, but added yes to largefile support (and
> > ignored the slight typo over folder locations, 'grass_current
> > / grass_trunk'.)
> you mean the wiki page?
Yep: http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu#Dependencies
"download latest source code from GRASS SVN repository in a directory on the
system (e.g. /usr/local/src)
svn checkout https://svn.osgeo.org/grass/grass/branches/releasebranch_6_4 \
grass_current
Above command places GRASS' source code in /usr/local/src/grass_trunk...."
For the text to remain consistent in the example (and for beginners of
compiling and using linux, e.g. me!)) this should fix any confusion:
Thanks
John
