[GRASS-user] importing dem files: projection details?
Tyler Smith
tyler.smith at eku.edu
Tue Mar 23 16:37:01 EDT 2010
On 03/21/2010 07:23 PM, Markus Neteler wrote:
> I get actually a somewhat different result (GDAL trunk):
> gdalinfo m40.dem
> Driver: USGSDEM/USGS Optional ASCII DEM (and CDED)
> Files: m40.dem
> Corner Coordinates:
> Upper Left ( 1447.317, 1055.177) (Invalid angle,Invalid angle)
> Lower Left ( 1447.317, 1042.411) (Invalid angle,Invalid angle)
> Upper Right ( 1457.509, 1055.177) (Invalid angle,Invalid angle)
> Lower Right ( 1457.509, 1042.411) (Invalid angle,Invalid angle)
> Center ( 1452.413, 1048.794) (Invalid angle,Invalid angle)
> Band 1 Block=1223x1532 Type=Float32, ColorInterp=Undefined
> NoData Value=-32767
> Unit Type: ft
> You may want to signal this as GDAL bug in the GDAL butracker:
> http://trac.osgeo.org/gdal/
> Unless GDAL doesn't read it correctly, it won't be understood by GRASS.
> I tested with
> ftp://ftp.kymartian.ky.gov/dems_usgs/m39.dem.zip
> Markus
Thanks,
I'll file a bug report when I have a moment.
Tyler
