[GRASS-user] error with r.terraflow
Achim Kisseler
ak7 at jupiter.uni-freiburg.de
Thu Mar 25 04:10:14 EDT 2010
> Error:
> Assertion failed: nrows * ncols == str->stream_len(), file
> grass2str.h,line 144
> This application has requested the Runtime to terminate it in an unusual
> way. Please contact the application's support team for more information.
about the error: I dont know, but:
can you give some more information about the data you are using?
And: can you post the commands you are used? (You can find the command
line equivalent for the gui in the tab "Command Output")
Regards,
Achim
