[GRASS-user] Imporing shapefile to GRASS: v.in.ogr
Jim Blix
blix at wiktel.com
Mon Mar 29 11:08:54 EDT 2010
I'm working on both the WinGRASS and Linux versions of GRASS. I am using the
Neteler/Mitasove text to learn the basics of GRASS. I'm using version (6.4
ORC5 2009) on Linux (Ubuntu 9.10) with the old tcl/tk GUI to stay consistent
with the book.
I'm stuck in trying to import a shapefile to the GRASS vector format with
v.in.ogr. WinGRASS MSYS seems to produce a good GRASS vector file with
topology, but on the Linux platform it produces a buffer overflow message
and a display that shows only one of about 117 polygons. I've tried
launching v.in.ogr in both the gui and from the command line with the same
result. On a related note, I can't seem to get the newer GUI to launch on
the Linux platform, but I'll solve that problem later.)
My terminal dialog is in the attached file.
http://n2.nabble.com/file/n4818504/terminal_output terminal_output
View this message in context: http://n2.nabble.com/Imporing-shapefile-to-GRASS-v-in-ogr-tp4818504p4818504.html
Sent from the Grass - Users mailing list archive at Nabble.com.
