[GRASS-user] problem with v.out.ogr & pgsql
Giovanni Manghi
giovanni.manghi at gmail.com
Tue Mar 30 19:21:23 EDT 2010
Hi all,
I'm trying to export a polygon from GRASS to postgis and the command I'm
using is like this
v.out.ogr -c input=polygon at mapset type=area dsn=PG:host=localhost
dbname=postgis user=users password=users format=PostgreSQL
but I always get
ERROR 1: AddGeometryColumn failed for layer
polygon at mapset, layer creation has failed.
ERROR: Unable to create OGR layer
The database is spatially enabled and the user has the right permissions
to write in it.
Didn't had much more success with v.out.ogr.pg.py has the error message
is the same.
Any hint?
thanks in advance
-- Giovanni --
