[GRASS-user] Stream flow direction map
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Sat May 1 09:22:27 EDT 2010
Nikos:
> >>>> While there is a proper (vector) contour map and a very clean stream
> >>>> network map (digitised from scratch upon topographic maps of 1:50.000)
> >>>> available, the flow direction map is missing.
> >>> is the direction map bound to a specific stream network, i.e. the one
> >>> that r.watershed or r.stream.extract produces  or  is it an independent
> >>> one, based solely on the input elevation model and its (x-y-z?)
> >>> resolution?
Micha:
> >> It's not clear if your friend needs a flow direction raster (normally,
> >> AFAIK, flow direction refers to a raster, where each cell has a value
> >> indicating which is the next downstream cell) or if he want to see the
> >> flow direction of streams in his stream network.
Nikos:
> > A flow direction raster map is required. And my silly question (because I
> > am not a hydro-specialist) is whether the flow direction production is
> > an independent process from the algorithm that produces the streams.
Micha:
> The r.watershed process makes several rasters: catchments, streams, flow
> direction, flow accumulation, and others if you want.
> > Why? Because the self-provided streams are of very high resolution and
> > accuracy (so why bother to extract them with potential errors like
> > circles in the connection of two segments of a stream, of ladder
> > effects).
> I've found that Markus Metz's newer r.watershed (part of GRASS 6.5, not
> 6.4) does a good job of eliminating these problems when you choose the
> MFD (Multi flow direction) algorithm.
Good to know! I haven't been following all this hydro-related development but
I am impressed (again) to see how powerfull grass-gis is.
> In any case, probably the best approach is to use the already digitized
> streams as input to the r.carve module (or r.stream.carve , Jarek's new
> hydrology extension) to produce an "improved" DEM, then use that
> resulting DEM to rerun r.watershed and get everything out as a
> consistent set of data layers.
OK. I think Jarek and Achim understood the problem quickly and suggested this
as the best method. Myself have a clear picture now of why r.carve is really
useful here.
Thank you Micha, Nikos
