[GRASS-user] v.generalize crash
Markus Metz
markus.metz.giswork at googlemail.com
Wed May 5 04:47:10 EDT 2010
On Tue, May 4, 2010 at 6:52 PM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Nikos Alexandris ha scritto:
>> Does it crash immediately or after a long time? It works for me in a small
>> file (boundaries though, not lines) and takes forever (still running after
>> 15min in a big file containing contours) but no crash.
> It is a memory error: when filled up it crashes. Obviously this does not happen with
> simpler layers.
>From the manual: "Snakes Algorithm is (asymptotically) the slowest
among the algorithms presented above. Also, it requires quite a lot of
memory. This means that it is not very efficient for maps with the
lines consisting of many segments."
Try another smoothing algorithm, e.g. chaiken.
HTH,
Markus M
