[GRASS-user] r.proj and r.resamp.rst issues -2
Bulent Arikan
bulent.arikan at gmail.com
Thu May 6 20:11:25 EDT 2010
I might have found a solution to my problem, which I shared with you earlier
today. I am writing about it in case someone else has a similar issue and
this may be a way of solving the problem. However, I am not certain if this
is the easiest or the most practical way of getting the results.
The problem was the presence of few negative value cells in 'cubic'
reprojected DEMs (from Latlong to UTM). I ran r.mapcalc to make these
negative cells NULLs. Then, I ran 'r.fillnulls' in that part of the DEM and
patched the 'filled' map with the original map (the one that has NULLs).
Finally, I interpolated the resultant (i.e., patched) imagery from 30m to
10m. The values in 10m DEM look accurate and free of negative value cells.
If you know another way of doing it and share with me, I will greatly
appreciate.
BÜLENT ARIKAN
School of Human Evolution and Social Change
Arizona State University
Tempe - AZ
85287-2402
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100506/edbe17e8/attachment.html
