[GRASS-user] GRASS 7.0 - OS X install problem
    Stuart Edwards
    sedwards2 at cinci.rr.com
    Sat May  8 18:00:49 EDT 2010
On May 8, 2010, at 4:19 PM, William Kyngesburye wrote:
> If you add to the PATH before configuring, it should find the system python for compilation.  Just make sure you have wxpython installed for the system or python.org (the wxpython included in the system is a bit old).  At runtime it will still fall back to macports.
> Either you can default to the system (or python.org) python for everything by changing your .bash_profile to remove or reorder the macports bin dir, or change it just for GRASS by adding this to your .bash_profile
> export GRASS_PYTHON=/usr/bin/pythonw2.6
That took care of it - it opens fine now.
> There is already an internal wrapper in GRASS that handles the 32bit part.  It just needs to be able to find a usable python, either automatically (using the current PATH) or with GRASS_PYTHON.
thanks for your help
Stu
