[GRASS-user] Landsat Stack import and export
Markus Metz
markus.metz.giswork at googlemail.com
Mon May 10 08:52:21 EDT 2010
2010/5/10 António Rocha <antonio.rocha at deimos.com.pt>:
> Greetings
> Regarding the possibility of exporting an GROUp, using r.in.gldal,
r.out.gdal you mean?
> the groups are not listed in that menu. So the user cannot see the available
> groups.
g.list type=group
will list all groups
> It's still processing but IO have one question: The processing bar restarted
> at least 3 times, what is happening?
If you export a group, each raster map is exported separately, even if
they all end up in one file. If you use r.out.gdal --verbose, there
would be several messages like
Exporting raster map <raster_name> (band <number>)...
and for each, the progress bar starts anew.
> Because it file, now, it seems that
> it's not "growing". Is it doing some file-check or something?
Depending on the grass version you are using, there might be some
checks first to prevent potential data loss (latest 6.4+).
Note that r.out.gdal uses the current computational region (resolution
and extends) for export.
Markus M
> Markus Metz wrote:
>> 2010/5/7 Markus Neteler <neteler at osgeo.org>:
>>> 2010/5/7 António Rocha <antonio.rocha at deimos.com.pt>:
>>>> Greetings
>>>> I've a Landsat image with 6 bands in Tif format. I need to import into
>>>> grass, do some processing and export the same band in a Stack.
>>>> The import is easy using r.in.gdal but my difficulty is to export 6
>>>> bands in
>>>> one single file. Is it possible using GRASS?
>>> To my knowledge no.
>> Sure it is. Create a group in GRASS, export the group (r.out.gdal
>> input=<group_name>) to a file format that supports multiple bands,
>> e.g. GeoTIFF.
>> Markus M
>> __________ Information from ESET NOD32 Antivirus, version of virus
>> signature database 5094 (20100507) __________
>> The message was checked by ESET NOD32 Antivirus.
>> http://www.eset.com
> __________ Information from ESET NOD32 Antivirus, version of virus signature
> database 5100 (20100510) __________
> http://www.eset.com
