[GRASS-user] Question with Python-SWIG example [SEC=UNCLASSIFIED]
Andrew MacIntyre
Andrew.MacIntyre at acma.gov.au
Tue May 11 20:58:50 EDT 2010
Bah! typo...
> > But I still don't see what happens when a function returns a CELL*
> > which is subsequently passed to a function accepting a void*, or
> > vice-versa. This is common enough that if SWIG can't handle it, we
> > need to use something other than SWIG.
> That seems to be what the SWIG Pointer Library function ptrcast() is
> for,
> according to http://www.swig.org/Doc1.1/HTML/Typemaps.html, so
> something like (in Python):
> import GrassMod
> pCELL = GrassMod.Returns_CELLptr()
> pvoid = GrassMod.castptr(pCELL, "void *")
above line should read:
pvoid = GrassMod.ptrcast(pCELL, "void *")
> result = GrassMod.Takes_voidptr(pvoid)
> (substitute the correct name of the GRASS SWIG module for "GrassMod")
Cheers,
Andrew.
-------------------------> "These thoughts are mine alone!" <---------
Andrew MacIntyre Operations Branch
tel: +61 2 6219 5356 Communications Infrastructure Division
fax: +61 2 6253 3277 Australian Communications & Media Authority
email: andrew.macintyre at acma.gov.au http://www.acma.gov.au/
If you have received this email in error, please notify the sender immediately and erase all copies of the email and any attachments to it. The information contained in this email and any attachments may be private, confidential and legally privileged or the subject of copyright. If you are not the addressee it may be illegal to review, disclose, use, forward, or distribute this email and/or its contents.
Unless otherwise specified, the information in the email and any attachments is intended as a guide only and should not be relied upon as legal or technical advice or regarded as a substitute for legal or technical advice in individual cases. Opinions contained in this email or any of its attachments do not necessarily reflect the opinions of ACMA.
