[GRASS-user] problems starting Grass6.3 on Windows
Vishal Mehta vishalm1975 at gmail.com
Wed May 12 16:29:51 EDT 2010
As i mentioned earlier, Grass6.3 was working earlierwith my own mapsets -
but now is not. The only difference since then that i can remember is that I
installed Qgis, and started experimenting with postgresql an dpostgis as
well...i dont quite see if that could impact Grass runs..but am just
guessing here..
Martin, I tried your May 12 Grass 6.5 daily build.
I get the same error regarding g.region. When i try to run it from the
command line, it enters grass. but then i cant use d.mon, so i try gis.m and
at this point i get the same original error.
is this something to do with the gis manager? I tried to start with
wx-python gui but got a different error there.
Vishal
On Tue, May 11, 2010 at 10:30 PM, Martin Landa <landa.martin at gmail.com>wrote:
> Hi,
> 2010/5/12 Milton Cezar Ribeiro <miltinho.astronauta at gmail.com>:
> > Is there a why of you use grass 6.3?
> > How about you try grass 6.4R6?
> or daily builds
> http://josef.fsv.cvut.cz/wingrass/
> Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa<http://gama.fsv.cvut.cz/%7Elanda>
Vishal K. Mehta, PhD
Scientist
Stockholm Environment Institute - US
133 D St Suite F
Davis CA 95616
www.sei-us.org
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100512/7cd3b6e3/attachment-0001.html
