[GRASS-user] Re: dems from coordinate lists
Hanlie Pretorius hanlie.pretorius at gmail.com
Fri May 14 05:49:36 EDT 2010
Hi Jamie,
Thanks, this worked perfectly.
Regards
Hanlie
2010/5/13, Jamie Adams <jaadfoo at gmail.com>:
> Did you adjust the region also?  To do this properly, you need to first scan
> the file using r.in.xyz to get the extents.  I'd also use the shell style
> output.
> r.in.xyz -sg input="2628cc.ORT.xyz" output="dem_2628cc_25m_xyz
> Should return something like:
> n=1000 s=500 w=500 e=1000 t=### b=###
> (you can ignore the t & b output)
> This is the extent of the points, which are going to be the center of the
> output pixels.  Since the region is defined as pixel edge, you need to
> expand the region 1/2 a pixel in each direction to ensure the points are in
> the center of the pixel.  At 25m spacing, your region should be set as:
> g.region n=1012.5 s=487.5 w=487.5 e=1012.5 res=25
> - Jamie
> On Thu, May 13, 2010 at 9:02 AM, Hanlie Pretorius <
> hanlie.pretorius at gmail.com> wrote:
>> Hi Jamie,
>> I tried r.in.xyz:
>> (r.in.xyz input="2628cc.ORT.xyz" output="dem_2628cc_25m_xyz"
>> method="mean" type="FCELL" x=1 y=2 z=3 zscale=1.0 percent=100)
>> but I still get the rows of no data in the result.
>> Hanlie
>> > You want the points to represent cell centers so you need to expand your
>> > region 1/2 pixel in all four directions.  Also look at using r.in.xyz,
>> > it
>> > works directly on this type of data.
>> > Jamie
>> > On Thu, May 13, 2010 at 7:26 AM, Hanlie Pretorius <
>> >> Hi,
>> >> I've obtained DEMs in text files with columns X, Y and Z at 25m
>> >> spacing. The first three entries in the text file are:
>> >> X,Y,Z
>> >> 99550,2.9883e+06,1473.47
>> >> 99550,2.98828e+06,1473.57
>> >> 99550,2.98825e+06,1473.63
>> >> To me it seems the easiest way to import these is the following:
>> >> 1. v.in.ascii
>> >> 2. Set the region to the extents of new vector file and the resolution
>> to
>> >> 25m.
>> >> 3. v.to.rast.
>> >> This 'works' but I get horizontal strips of no data in my raster DEM
>> >> at 25m spacings.
>> >> Also, when I look at the raster and the vector layer together, the
>> >> vector points are not always on the edges of the raster cells.
>> >> Can someone perhaps help me to fix this?
>> >> g.region:
>> >> projection: 99 (Transverse Mercator)
>> >> zone:       0
>> >> datum:      ** unknown (default: WGS84) **
>> >> ellipsoid:  wgs84
>> >> north:      2988300
>> >> south:      2959850
>> >> west:       74300
>> >> east:       99550
>> >> nsres:      25
>> >> ewres:      25
>> >> rows:       1138
>> >> cols:       1010
>> >> cells:      1149380
>> >> v.info:
>> >>  | Layer:           dem_2628cc_25m at C83
>> >>  | Mapset:          C83
>> >>  | Location:        sa_tm_19deg_E
>> >>  | Database:        C:\Hanlie\grassdata
>> >>  | Title:
>> >>  | Map scale:       1:1
>> >>  | Map format:      native
>> >>  | Name of creator: Administrator
>> >>  | Organization:
>> >>  | Source date:     Thu May 13 16:06:07 2010
>> >>  |   Type of Map:  vector (level: 2)
>> >>  |   Number of points:       1151529         Number of areas:      0
>> >>  |   Number of lines:        0               Number of islands:    0
>> >>  |   Number of boundaries:   0               Number of faces:      0
>> >>  |   Number of centroids:    0               Number of kernels:    0
>> >>  |   Map is 3D:              Yes
>> >>  |   Number of dblinks:      0
>> >>  |         Projection: Transverse Mercator
>> >>  |               N:           2988300    S:           2959850
>> >>  |               E:             99550    W:             74300
>> >>  |               B:           1429.79    T:            1740.2
>> >>  |   Digitization threshold: 0
>> >>  |   Comments:
>> >> r.info:
>> >>  | Layer:    dem_2628cc_25m at C83             Date: Thu May 13 16:15:50
>> 2010
>> >>  | Mapset:   C83                            Login of Creator:
>> >> Administrator
>> >>  | DataBase: C:\Hanlie\grassdata
>> >>  | Title:    Categories ( dem_2628cc_25m )
>> >>  | Timestamp: none
>> >>  |   Type of Map:  raster               Number of Categories: 0
>> >>  |   Data Type:    DCELL
>> >>  |   Rows:         1138
>> >>  |   Columns:      1010
>> >>  |   Total Cells:  1149380
>> >>  |            N:    2988300    S:    2959850   Res:    25
>> >>  |            E:      99550    W:      74300   Res:    25
>> >>  |   Range of data:    min = 1429.850000  max = 1739.410000
>> >>  |   Data Source:
>> >>  |    Vector Map: dem_2628cc_25m at C83 in mapset C83
>> >>  |    Original scale from vector map: 1:1
>> >>  |   Data Description:
>> >>  |    generated by v.to.rast
>> >>  |   Comments:
>> >>  |    v.to.rast input="dem_2628cc_25m at C83" output="dem_2628cc_25m"
>> >> use="z"\
>> >>  |     type="point,line,area" layer=1 value=1 rows=4096
>> >> Thanks
>> >> Hanlie
>> >> _______________________________________________
>> >> grass-user mailing list
>> >> grass-user at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/grass-user
>> > -------------- next part --------------
>> > An HTML attachment was scrubbed...
>> > URL:
>> http://lists.osgeo.org/pipermail/grass-user/attachments/20100513/dd33d293/attachment.html
>> > End of grass-user Digest, Vol 49, Issue 24
