[GRASS-user] Creation and managing Location/Mapset
Luís Ferreira
lferreira75.1 at gmail.com
Mon May 17 15:53:00 EDT 2010
> 1- Should I create 1 Location with 4 different mapsets (for each of
> the considered scales)? Or should I use 1 location, one mapset and 4
> different regions?
one location if all the analysis will be done with one coordinate system
one mapset = one region, one resolution
so, perhaps, is better you to use four different mapsets (four levels)
> 2- How can I define a region that is not a perfect square' Because in
> "Set Region" we have North, South, East and West Boundaries. And my
> regions are not perfect squares.
A region don't need to be square. And you can use an analysis mask.
Raster > Mask, or r.mask.
Luís Ferreira
