[GRASS-user] GRASS sites file
Luisa Peña
luisapena1979 at gmail.com
Wed May 19 04:24:09 EDT 2010
The only warning that i get is:
warning: format not a string literal and no format arguments
Where is that "cheap trick". Before I do any implementation i.ptr I have to
understand that its classification works. So far, fraom all the messages
that I have read, no one can use the classification...
Luisa
2010/5/19 Markus Metz <markus.metz.giswork at googlemail.com>
> Hamish wrote:
> > Luisa wrote:
> >> What is a GRASS sites file? How can I obtain this?
> > a sites file is what vector points maps were called in earlier versions
> > of GRASS.
> > grass-addons/imagery/i.pr/TODO:
> > This module set was developed for GRASS 5.
> > TODO:
> > - change to ANSI prototypes
> > - follow SUBMITTING rules
> > - change sites to vector
> > There is a "cheap" coding option which supports the old sites API while
> > using new vector points maps. I don't know if these modules use that
> > or not. The real solution is to make them use the new vector API (not
> > so hard, documented into the wiki somewhere?).
> If i.pr compiles without warnings (regarding the sites API) it should
> work in 6.x. Otherwise it's not much work to change it to use the new
> vector API.
> Markus M
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100519/a4a8eb1a/attachment-0001.html
