[GRASS-user] problems starting Grass6.3 and 6.5svn on Windows:
"Error setting
region (Problem with g.region?):child killed:unknown signal"
Vishal Mehta
vishalm1975 at gmail.com
Wed May 19 15:19:32 EDT 2010
I could use some help getting Grass to work on my Windows XP..
Here's some information:
- I've tried using Grass6.3 and Grass 6.5svn installers, bith are giving the
same problem. After the installation, upon starting Grass, as its loading
the GUI, it crashes after this message: Error setting region (Problem with
g.region?): child killed: unknown signal."
- After that i get another message window called Error in Startup script
with a long list of error messages that starts with 'cant rad parts(w) no
such variable....;
- when i starting GRASS using the Msys interface, I get the same message
after the splash screen, but Grass does start up. I can then run commands
like g.list rast etc, but cannot start the visual interface - i can never
start the gis.m display (it gives the same error message).
- My GRASS 6.3 installation was working fine until a couple of weks ago. I
cant figure out what could have changed in the meantime. I've installed QGIS
in the meantime but i dont see how that could interfere..
Thanks,
Vishal
Vishal K. Mehta, PhD
Scientist
Stockholm Environment Institute - US
133 D St Suite F
Davis CA 95616
www.sei-us.org
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100519/df1ecf42/attachment.html
