[GRASS-user] export as eps/svg ind grass7?
Hamish hamish_b at yahoo.com
Sat May 22 11:54:37 EDT 2010
Achim wrote:
> I know that it is not possible in grass65,
no my friend, it is available:   d.out.file
   format   Graphics file format
            options: png,ppm,tif,geotiff,jpg,bmp,ps,eps,svg,pdf
And of course v.out.svg.
See d.mon for details on the Cairo and PS (PostScript) drivers
which are another way to go.
and of course ps.map or ps.output PostScipt [-> PDF] -> Inkscape is
great if you need print quality output.
> but can one export the graphics display to svg or eps in grass7
> (from gui-display)?
there is a save-as pull down menu in the map display. I can't remember
what's on it except that GeoTiff is on the planned feature list.
> Alternatively I would like to load my workspace settings to
> a xmon in order to export from there. Is that possible?
> (I really dont want to rebuild the layer settings from the
> shell again ;-) )
GRASS 7 doesn't have xmons, but the PS and Cairo drivers there are
much better than in GRASS 6. (mostly the xmons hold them back in grass 6)
good luck,
Hamish
