[GRASS-user] Using an external hard drive as data source
Hanlie Pretorius
hanlie.pretorius at gmail.com
Mon May 24 05:23:01 EDT 2010
I'm using GRASS 6.4 on two machines in different locations (one Win XP,
the other Ubuntu 10.04), so I would like to keep my grassdata folder
on an external drive. However, when I try to run grass in Ubuntu using
the external hard drive (NTFS file system), I get the following error
as soon as I've selected the new data location and the GUI starts to
load:
Execution failed: 'g.region -u -g -p -c'
Details:
Error: MAPSET PERMANENT - permission denied
To run GRASS, I use the command 'sudo grass -wx'.
GRASS works fine when I run it from the internal hard drive.
Is there a way to get GRASS to work from the external drive?
Thanks
Hanlie
