[GRASS-user] Copying from a mapset in another data directory
Jonathan Greenberg
greenberg at ucdavis.edu
Tue May 25 15:26:04 EDT 2010
This ALMOST works, except "from" needs to take the form
rastername at mapset and "to" needs the form rastername. I can get the
"from" setup properly by appending "-m" to the gmlist call, but how do
I subsequently strip the @comet part for the "to" statement? Thanks!
Incidentally, this would be a good feature to add to g.copy.
--j
On Mon, May 24, 2010 at 8:40 PM, Nikos Alexandris
<nikos.alexandris at felis.uni-freiburg.de> wrote:
> Jonathan Greenberg wrote:
>> Excellent -- symlinking is working properly -- now on to my next
>> question -- is there a way to do some level of "batch" g.copy using a
>> wildcard, e.g.:
>> g.copy rast=ned_ca_masked_epsg3310_*@comet
>> Or do I have to specific each raster individually, along with its
>> target file name?
> Jonathan, would a for loop + g.mlist + g.copy get the job done? For example:
> for X in `g.mlist rast pat=ned_ca_masked_epsg3310_* mapset=comet` ; do
> g.copy rast="${X}","${X}" ; done
> Nikos
