[GRASS-user] r.grow.distance
Tue May 25 22:45:46 EDT 2010
fengel wrote:
> I produced an uncontinuous distance map as a result of r.grow.distance. Most
> parts of the distance map are smooth but there are some sharp edges in the
> map. This means that with a 100m resolution of the map in most parts of the
> map the distance value increases about 100 m with every pixel. At the sharp
> edges there are leaps of up to 1000m from pixel to pixel. Depending on the
> color map used for displaying the distance map you can also see these jumps
> clearly.
Can you provide a test case?
