[GRASS-user] Trying python scripts.
Marcello Gorini
gorini at gmail.com
Thu May 27 11:14:59 EDT 2010
Dear all,
This is kind of my first e-mail ever to ANY mailing list, so please forgive
me if I don't express myself in the best way. I will improve eventually.
I am a total beginner in python and GRASS (and any other programming
language), so I am trying to run the first examples found in
http://grass.osgeo.org/wiki/GRASS_and_Python.
I managed to run the shaded_relief one OK, but the one with respect to
mapcalc, I couldn't.
I copied a script found in
http://www.mail-archive.com/grass-dev@lists.osgeo.org/msg14669.html
(transcribed below) and tried to run it:
#!/usr/bin/env python
# g.parser demo script for python programing
#%module
#% description: g.parser test script (python) TUN
#%end
#%flag
#% key: f
#% description: A flag
#%end
#%flag
#% key: n
#% description: Another flag
#%end
#%option
#% key: raster1
#% type: string
#% gisprompt: old,cell,raster
#% description: Raster input map
#% required : yes
#%end
#%option
#% key: raster2
#% type: string
#% description: Raster2 input map
#% required : yes
#%end
#%option
#% key: output
#% type: string
#% gisprompt: new,cell,raster
#% description: Output
#% required : yes
#%end
import os
import sys
import grass.script as grass
def main():
output = options['output']
raster1 = options['raster1']
raster2 = options['raster2']
grass.mapcalc("$out = $rast1 + $rast2", out = output, rast1 = raster1,
rast2 = raster2)
if flags['f']:
print "Flag -f set"
else:
print "Flag -f not set"
if flags['n']:
print "Flag -n foi definida mas nao devia"
else:
print "Flag -n not set- GOOD"
print options
print flags
return 0
if __name__ == "__main__":
options, flags = grass.parser()
sys.exit(main())
It seems to run OK and “100%” is displayed in the GRASS prompt, but when I
tried to display the map, I found out that it wasn't created at all.
Just for you to know, to run the script I simply create it (say
“myscript.py”), give permissions and run it in a GRASS session with the
necessary options: > ./myscript.py output=outmap raster1=map1 raster2=map2
I am using Ubuntu 9.04 64bits and GRASS 6.4.ORC5.
Can anyone help me?
Best regards,
Marcello Gorini.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Trying-python-scripts-tp5109105p5109105.html
Sent from the Grass - Users mailing list archive at Nabble.com.
