[GRASS-user] Using a polygon as a Mask
António Rocha
antonio.rocha at deimos.com.pt
Thu May 27 12:16:58 EDT 2010
Thank you Christian
What I am affraid is that when I convert Vector to RASTER I will obtain
a mask that is not exacly the polygon in the boundaries of the polygon.
For instance, if a pixel is "cuttted" by the polygons boundaries is it
considered part odf the polygon or not?
Thanks
Antonio
Christian Schwartze wrote:
> There is no way to use a vector geometry in mapcalculator (or mapcalc)
> directly, hence, you have to convert it to raster before.
> Christian.
> From: "António Rocha" <antonio.rocha at deimos.com.pt>
> Sent: Thursday, May 27, 2010 2:08 PM
> To: "GRASS user list" <grass-user at lists.osgeo.org>
> Subject: [GRASS-user] Using a polygon as a Mask
>> Greetings
>> I have polygon that I want to use to define an for which I want to
>> calculate some indicators (almost as a mask). Is it possible to use
>> it directly in mapcalculator or do I have to convert it to RASTER and
>> only then I can use it in mapcalculator as a mask?
>> Thanks
>> Best regards,
>> Antonio
>> __________ Information from ESET NOD32 Antivirus, version of virus
>> signature database 5149 (20100527) __________
>> The message was checked by ESET NOD32 Antivirus.
>> http://www.eset.com
>> grass-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5150 (20100527) __________
http://www.eset.com
