[GRASS-user] Re: Trying python scripts.
Marcello Gorini gorini at gmail.com
Thu May 27 12:25:17 EDT 2010
Hello Nikos,
Marcello Gorini.
Nikos Alexandris wrote:
> Hi Marcello,
> Marcello Gorini:
>> This is kind of my first e-mail ever to ANY mailing list, so please
>> forgive
>> me if I don't express myself in the best way. I will improve eventually.
>> I am a total beginner in python and GRASS (and any other programming
>> language), so I am trying to run the first examples found in
>> http://grass.osgeo.org/wiki/GRASS_and_Python.
>> I managed to run the shaded_relief one OK, but the one with respect to
>> mapcalc, I couldn't.
>> I copied a script found in
>> http://www.mail-archive.com/grass-dev@lists.osgeo.org/msg14669.html
>> (transcribed below) and tried to run it:
>> #!/usr/bin/env python
>> # g.parser demo script for python programing
>> #%module
>> #%  description: g.parser test script (python) TUN
>> #%end
>> #%flag
>> #%  key: f
>> #%  description: A flag
>> #%end
>> #%flag
>> #%  key: n
>> #%  description: Another flag
>> #%end
>> #%option
>> #%  key: raster1
>> #%  type: string
>> #%  gisprompt: old,cell,raster
>> #%  description: Raster input map
>> #%  required : yes
>> #%end
>> #%option
>> #%  key: raster2
>> #%  type: string
>> #%  description: Raster2 input map
>> #%  required : yes
>> #%end
>> #%option
>> #%  key: output
>> #%  type: string
>> #%  gisprompt: new,cell,raster
>> #%  description: Output
>> #%  required : yes
>> #%end
>> import os
>> import sys
>> import grass.script as grass
>> def main():
>>     output = options['output']
>>     raster1 = options['raster1']
>>     raster2 = options['raster2']
>>     grass.mapcalc("$out = $rast1 + $rast2", out = output, rast1 =
>> raster1,
>> rast2 = raster2)
>>     if flags['f']:
>>         print "Flag -f set"
>>     else:
>>         print "Flag -f not set"
>>     if flags['n']:
>>         print "Flag -n foi definida mas nao devia"
>>     else:
>>         print "Flag -n not set- GOOD"
>>     print options
>>     print flags
>>     return 0
>> if __name__ == "__main__":
>>     options, flags = grass.parser()
>>     sys.exit(main())
>> It seems to run OK and “100%” is displayed in the GRASS prompt, but when
>> I
>> tried to display the map, I found out that it wasn't created at all.
> If there are no errors and the script ran fine, maybe you just need to
> check
> the region settings?
>> Just for you to know, to run the script I simply create it (say
>> “myscript.py”), give permissions and run it in a GRASS session with the
>> necessary options: > ./myscript.py output=outmap raster1=map1
>> raster2=map2
>> I am using Ubuntu 9.04 64bits and GRASS 6.4.ORC5.
> For example:
> # check region extent, etc.
> g.region -p
> # set region extent and resolution to the map of your interest
> g.region rast=outmap -pa
> # give color
> r.colors rast=outmap color=rainbow
> # try to display
> d.mon x0 && d.rast outmap
> # is it there?
> Regards, Nikos
> No, it is not there. To make sure I set the region to the input map:
> g.region rast=map1 -pa
> d.mon x0 && d.rast map1
> OK, it is there. Then I ran the script:
> ./myscript.py output=outmap raster1=map1 raster2=map2
> After processing, I tried:
> d.rast outmap
> But then:
> ERROR: Raster map <outmap> not found
> What could be wrong?
> Best regards,
> Marcello.
> P.S.: By the way, is this the right way to quote answers?
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Trying-python-scripts-tp5109105p5109431.html
Sent from the Grass - Users mailing list archive at Nabble.com.
