[GRASS-user] Re: Trying python scripts.
Marcello Gorini
gorini at gmail.com
Fri May 28 10:28:21 EDT 2010
Nikos Alexandris wrote:
> Marcello Gorini:
>> ...let's go step by step:
>> ls -l myscript.py
>> -rwxr-xr-x 1 marcello marcello 1227 2010-05-28 08:13 myscript.py
> looks fine
>> g.gisenv
>> GISDBASE=/home/marcello/grassdata
>> LOCATION_NAME=Ocean_floor
>> MAPSET=level4
>> MONITOR=x0
>> GRASS_GUI=tcltk
> just out of curiosity (and not that, I think, it makes any differene): are
> you
> running (grass and) the script via the gui's command line or in text-mode?
>> g.region -p
>> projection: 99 (Mercator)
>> zone: 0
>> datum: wgs84
>> ellipsoid: wgs84
>> north: 3947900
>> south: 3633400
>> west: -7366700
>> east: -7022600
>> nsres: 3700
>> ewres: 3700
>> rows: 85
>> cols: 93
>> cells: 7905
> looks ok (below also)
>> r.info map1
>> | Range of data: min = 0.000000 max = 10000.000000
>> r.info map2
>> | Range of data: min = 1000.000000 max = 1000.000000
>> Result of "r.info outmap":
>> ERROR: Raster map <outmap> not found
> Hmmm... I don't know what could be wrong here. I guess running directly
> in-
> grass what the python script is expected to do ( r.mapcalc "outmap = map1
> map2" ) is ok, isn't it?
> Could you also please copy-paste the exact (python) command you use within
> the
> grass-session to get the desired "outmap"?
> Nikos
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Ok, so answering your questions:
you
No gui, everything using the terminal.
in-
Yep!
the
Sure:
python myscript.py raster1=map1 raster2=map2 output=outmap
Well, I think that eventually we will find out that the problem lies between
my chair and my computer, and you are going to be mad with me :)
But for now, let's keep going.
Cheers,
Marcello.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Trying-python-scripts-tp5109105p5113299.html
Sent from the Grass - Users mailing list archive at Nabble.com.
