[GRASS-user] GRASS GUI assessment
    Mohammed Rashad
    rashadkm at yahoo.com
    Sun May 30 01:08:21 EDT 2010
 data catalog uses only one outdated gui module which is mapdisplay.py all other modules are from latest grass trunk.
mapdisplay should be kept as seperate for proper working of data catalog.
if needed i will consider updating it also. i cannot use latest mapsdisplay.py from grass trunk, the reason is
in mapdisplay.py from trunk it use wx.frame and i need wx.panel inheritance for embedding mapFrame inside the notebook panel
Regards,
Rashad
To: Mohammed Rashad <rashadkm at yahoo.com>
Cc: grass-user at lists.osgeo.org
Sent: Sat, May 29, 2010 9:25:38 PM
Subject: Re: [GRASS-user] GRASS GUI assessment
2010/5/29 Mohammed Rashad <rashadkm at yahoo.com>:
> You please check this addon
> a new grass gis manager
> http://trac.osgeo.org/grass/browser/grass-addons/gui/wxpython/data_catalog
> the screenshots are old. not enough time to update :)
> here is the code
the problem of the data catalog is that it contains copy of several
wxGUI modules (mostly out-dated). It should be ideally implemented as
one python module (data_catalog.py). The developer of the data catalog
can send patches via Trac for wxGUI code in trunk to make this
solution possible.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100529/cebc2a46/attachment.html
