[GRASS-user] v.buffer: circles around points
Achim Kisseler ak7 at jupiter.uni-freiburg.de
Wed Nov 3 04:54:55 EDT 2010
Hi Sharon,
that sould be the radius, but:
due to changing distances on latitude, the circle is not a true circle,
as you can see when you reproject the map.
The buffer distance is in degree.
Hope, everything is correct,
regards,
Achim
Am 03.11.2010 06:44, schrieb Sharon M:
> Hi,
> I'm starting to use v.buffer to create circles around points on
> Lat/Long vector maps.
> When entering a value for the distance parameter for v.buffer to
> create circles for points on lat/long maps, is the distance entered
> the radius of the circle or is it the diameter? or some other
> variable?
> Thanks in advance,
> Sharon
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
