[GRASS-user] Re: Constrain the output of v.random
leonidas
leonidas_liakos at yahoo.gr
Thu Nov 4 06:00:48 EDT 2010
I need the defined "Number of points to be created" to be inside the
polygons. If I follow your method some of them will remain out of the
polygons. I need to get 10 points that will fall inside the polygons NOT to
define 10 points and then select only the points that they are in polygons.
Thanks for your reply!
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Constrain-the-output-of-v-random-tp5704498p5704721.html
Sent from the Grass - Users mailing list archive at Nabble.com.
