[GRASS-user] Re: Having some difficulties with v.to.rast
Luisa Peña luisapena1979 at gmail.com
Fri Nov 5 10:31:44 EDT 2010
Thanks for your feedback Achim
Now I did:
v.centroids --overwrite input=teste01 at Brazil
output=teste01_centroid at Brazil cat=1
step=0
Vector map <teste01_centroid> already exists and will be overwritten
Processing features...
2 new centroids placed in output map
Copying attribute table(s)...
Building topology for vector map <teste01_centroid>...
Registering primitives...
4 primitives registered
15 vertices registered
Building areas...
2 areas built
2 isles built
Attaching islands...
Attaching centroids...
Number of nodes: 4
Number of primitives: 4
Number of points: 0
Number of lines: 0
Number of boundaries: 2
Number of centroids: 2
Number of areas: 2
Number of isles: 2
v.category complete. 2 features modified.
(Fri Nov 05 14:23:15 2010) Command finished (0 sec)
and then:
v.to.rast --overwrite
input=teste01_centroid at Braziloutput=teste01centroid at Brazil use=val
value=5
I got:
Loading data...
Pass 1 of 2:
Reading areas...
Reading features...
Writing raster map...
Pass 2 of 2:
Reading areas...
Converted areas: 2 of 2
Converted points/lines: 0 of 0
v.to.rast complete.
And now It seems all OK :)
But I do have 1 (last) question:
When I use the Query pixel value feature, I get this:
568209.941176|9248338.294118||5|Value 5 Does this means that each pixel has
a raster value of 5 right? Because I'm also getting Value 5 and I don't what
it is..
Thanks
Luisa
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101105/2b1ba5d7/attachment.html
