[GRASS-user] Slope categories from DEM ?
Daniel Victoria daniel.victoria at gmail.com
Sat Nov 6 16:49:12 EDT 2010
Rich,
The if syntax in r.mapcalc is as follows:
if(test condition, response if true, response if false)
So, by reversing the test in the if statement will give you values of
1 for low slope areas.
Check out the r.mapcalc man page for the complete if syntax
Daniel
On Sat, Nov 6, 2010 at 4:06 PM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
> On Sat, 6 Nov 2010, Martin Landa wrote:
>> r.mapcalc 'slope_30 = if(slope_map > 30, 1, 0)'
>> r.mapcalc generates raster map with two values - 1 for areas where slope
>> is greater then 30% and 0 for areas where slope is lower or equal then
>> 30%.
> Martin,
>  Is the reverse 'slope_30 = if(slope_map < 30, 1, 0)' mean that areas = 1
> are < than 30% and areas with 0 are >= 30%?
>  My question is the value of areas where slope = 30% are placed with the
> different mapcalc expressions.
> Thanks,
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
