[GRASS-user] Using v.colors in WinGRASS
Martin Landa landa.martin at gmail.com
Tue Nov 9 09:22:00 EST 2010
2010/11/9 Markus Metz <markus.metz.giswork at googlemail.com>:
> On Tue, Nov 9, 2010 at 12:55 PM, Luisa Peña <luisapena1979 at gmail.com> wrote:
>> Greetings
>> I'm using winGRASS6.4.1 (compiled from OSGEO4w) and I'm having a difficulty
>> on applying v.colors.
>> I have a raster map (r.reclass) that I convert to vector/areas. So far so
>> good...
>> But when I try to apply v.colors with this expression:
>> v.colors map=teste01_LULC at Regional column=cat color=aspect
>> I get this error:
>> Creating column <GRASSRGB> ...
>> E:/GRASS6/scripts/v.colors: v.db.addcol: command not found
try r44284, hopefully fixed.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
