[GRASS-user] Using v.colors in WinGRASS
Markus Metz
markus.metz.giswork at googlemail.com
Tue Nov 9 10:37:25 EST 2010
On Tue, Nov 9, 2010 at 3:22 PM, Martin Landa <landa.martin at gmail.com> wrote:
> 2010/11/9 Markus Metz <markus.metz.giswork at googlemail.com>:
>> On Tue, Nov 9, 2010 at 12:55 PM, Luisa Peña <luisapena1979 at gmail.com> wrote:
>>> Greetings
>>> I'm using winGRASS6.4.1 (compiled from OSGEO4w) and I'm having a difficulty
>>> on applying v.colors.
>>> I have a raster map (r.reclass) that I convert to vector/areas. So far so
>>> good...
>>> But when I try to apply v.colors with this expression:
>>> v.colors map=teste01_LULC at Regional column=cat color=aspect
>>> I get this error:
>>> Creating column <GRASSRGB> ...
>>> E:/GRASS6/scripts/v.colors: v.db.addcol: command not found
> try r44284, hopefully fixed.
Sorry, not related to whitespace, wingrass installations on German
systems have no whitespace in the path, but the same error:
Markus M
