[GRASS-user] Re: Need some help in converting a contour map to DEM
map...
nikmor
nikhil_morajkar at yahoo.com
Wed Nov 10 07:20:57 EST 2010
hello sir,
thanks for the link. I have tried it out and it works with v.surf.rst. But when I use r.surf.contour it takes a very very long time and it never ends. I would be thankful if you could suggest me something regarding the resolution(grid resolution 2d in g.region modules resolution tab).
thanks,
Nikhil Morajkar
Junior Software Engineer,
Department of Computer Science and Engineering,
Geo-Spatial Information Science & Engineering (GISE),
Advance Research Lab,
Indian Institute of Technology, Bombay (IITB)
Powai, Mumbai
--- On Wed, 11/10/10, Markus Neteler [via OSGeo.org] <ml-node+5723857-989940413-299324 at n2.nabble.com> wrote:
From: Markus Neteler [via OSGeo.org] <ml-node+5723857-989940413-299324 at n2.nabble.com>
Subject: Re: Need some help in converting a contour map to DEM map...
To: "nikmor" <nikhil_morajkar at yahoo.com>
Date: Wednesday, November 10, 2010, 2:00 PM
On Tue, Nov 9, 2010 at 12:28 PM, nikmor <[hidden email]> wrote:
> Hello friends
> I am trying to import an contour file and trying to come up with an DEM map
> from it. I tried it my way but end up with wrong output. I am looking
> forward for some one who can import this map and convert it to DEM and
> finally and most importantly we should be able to view the output in NVIZ. I
> have attached the folder having the contour data, this data is of IIT
> bombay.
Please take a look here.
http://grass.osgeo.org/wiki/Contour_lines_to_DEM
Markus
grass-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/grass-user
View message @ http://osgeo-org.1803224.n2.nabble.com/Need-some-help-in-converting-a-contour-map-to-DEM-map-tp5720519p5723857.html
To unsubscribe from Need some help in converting a contour map to DEM map..., click here.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Need-some-help-in-converting-a-contour-map-to-DEM-map-tp5720519p5724458.html
Sent from the Grass - Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101110/187b6620/attachment.html
