[GRASS-user] Exporting Vector data to SHP (v.out.ogr)- takes a lot
of time
Luis Lisboa
luislisboa1975 at gmail.com
Thu Nov 11 10:08:38 EST 2010
Greetings
I have produced a vector map (with r.to.vector) with the following metadata:
v.info test01
| Layer: teste01 |
| Mapset: Regional
| Database: E:\v3
| Title:
| Map scale: 1:1
| Map format: native
| Name of creator: orbit |
| Organization:
| Source date: Tue Nov 09 11:11:40 2010
| Type of Map: vector (level: 2)
| Number of points: 0 Number of areas: 213680
| Number of lines: 0 Number of islands: 73649
| Number of boundaries: 348770 Number of faces: 0
| Number of centroids: 213666 Number of kernels: 0
| Map is 3D: No
| Number of dblinks: 1
| Projection: Universal Transverse Mercator (zone 0)
| N: 8832707.83027649 S: 7028073.62772369
| E: 1347458.42001915 W: 200792.5777576
| Digitization threshold: 0
| Comments:
Now I'm trying to export it to SHAPEFILE but, after 10 minutes the
processing bar is not even in 40%. What might be happening? I mean, is it
some error with the vector or when I convert to vector (from raster)?
Because, taking more than 10 minutes to export to vector it's not normal (I
guess) and taking nearly 7 min to convert to vector also...
Thanks for the reply
Luis L
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101111/7866a576/attachment.html
