[GRASS-user] r.neighbors - annulus (torus) neighbor
Glynn Clements
glynn at gclements.plus.com
Mon Nov 15 09:33:21 EST 2010
Jasiewicz Jarosław wrote:
> while I need annulus (or torus) neighbor to some of my work I added
> easily it to neighbors (grass 65 delev) module. Because I do not won't
> to create a fork of that module I put it on that url:
If you need neighbourhood shape other than a square or circle, use the
weights= option.
Masks can be created using NumPy; e.g.
from numpy import *
r = 7 # outer radius
r0 = 3 # inner radius
d = sqrt(fromfunction(lambda x, y: (x-r)**2 + (y-r)**2, (2*r+1, 2*r+1)))
m = logical_and(d >= r0, d <= r)
savetxt('weights', m, fmt = '%d')
Or for smooth edges:
from numpy import *
m = minimum(1, maximum(0, (r-r0)/2 - abs(d - (r+r0)/2)))
savetxt('weights', m, fmt = '% .3f')
If you only need a mask (weights of 0 or 1), you can use anything
which can outupt PGM files (use the P2 "text" format and cut off the
header).
