[GRASS-user] How to delete deadends?
Patrick_schirmer patrick_GIS at gmx.ch
Mon Nov 15 11:48:59 EST 2010
Thanks Markus and Hamish,
Unfortunately v.clean rmdangle will not work for me. With Threshhold<0
it deletes more or less all lines, otherwise none. I guess it is because
the "nests" of lines consist of 4-20 lines and are all seperated from
each other.
Per defintion a line "is considered to be a dangle if no other line of
given /type/ is on at least one end node" (documentation v.clean
rmdangle). As I am searching for lines that have exactly one line as sum
of all connecting node, this tool doesn't help.
I will try to solve the problem by creating points out of the line
(nodes), buffering the points and delete the ones intersecting only one
line. But I still hope that there is a more direct solution to delete
the line as a geometry.
So if there are any other suggestions I would be happy about.
I'll keep you up to date in case I find a solution.
Cheers, Patrick
On 11/12/2010 09:51 PM, Hamish wrote:
> Patrick_schirmer wrote:
>> I have a lot of lines that are linked to another
>> forming various nets. Several of those lines are
>> deadends. Now I search for a option to delete
>> "dead-ends" within those networks. It would be
>> perfect to delete the lines, or to search for the
>> nodes that link to more than one line.
>> I was searching in v.generalize, v.net,
>> v.to.point, v.to.db but won't find the proper
>> approach.
> not a v.net specific thing, but in general for
> vector maps you can use v.clean to remove (or isolate)
> line "dangles" with the 'rmdangle' (or 'chdangle')
> tools.
> maybe that helps,
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101115/4e00cdc2/attachment-0001.html
