[GRASS-user] Re: Using i.gensig- How to keep original values
Nick Jachowski
njachowski at gmail.com
Wed Nov 17 10:48:59 EST 2010
I'm having a similar problem whereby every time I run i.gensig followed by
i.maxlik it results in a single class for all the pixels. This doesn't
happen when I use i.cluster with i.maxlik. I haven't analysed the sig file
closely to see if the problem might be there, but I will try that tomorrow.
At any rate, perhaps this is related to the problem Helena and Antonio are
reporting.
- Nick
On Wed, Nov 17, 2010 at 6:51 PM, Helena Herrera <helenaherrera1980 at gmail.com
> wrote:
> I had exacly the same problem. My solution was, by-hand, creating a reclass
> file and then run this.
> But, as far as I can see this is a major failure of i.gensig and
> Classification methdology. Or are we (me and Antonio) seeing this wrong?
> because, if training map sets values as 1000 or 2 or 3, they shold be kept
> in signature file, in order to be used in i.maxlik
> has anyone any solution?
> Helena
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101117/36e81fb2/attachment.html
