[GRASS-user] TRMM (3B43) handling
Markus Neteler
neteler at osgeo.org
Fri Nov 19 07:49:15 EST 2010
On Fri, Nov 19, 2010 at 8:40 AM, Markus Metz
<markus.metz.giswork at googlemail.com> wrote:
> nikos ves wrote:
>> On Wed, 2010-11-17 at 10:08 +0100, Markus Metz wrote:
>>> Another option:
>>> get binary grids from here
>>> ftp://disc2.nascom.nasa.gov/data/TRMM/Gridded/3B43_V6/
>>> read
>>> ftp://disc2.nascom.nasa.gov/data/TRMM/Gridded/3B43_V6/3B43.ctl
>>> import into a latlon location with r.in.bin -f -b north=50 south=-50
>>> east=180 west=-180 rows=400 cols=1440, e.g.
>>> r.in.bin -f -b input=3B43.100101.6.precipitation.bin
>>> output=3B43.100101.6.precipitation north=50 south=-50 east=180
>> i was comparing the output rasters with a png [1] a same period.
>> eg Jul_2006. it seems that in the bin [2] file N is S and vise versa.
>> The phenomenon can be seen clearly by comparing the western coast of
>> India between [1] and [2]
>> I don't think I'm doing something wrong, but can anyone cross check just
>> to be sure I didn't anything stupid on my side?
> Confirmed, that's maybe the reason why these binary grids are well hidden.
> Looks like there is no way around setting GCPs and using i.rectify,
> either with these binary grids or with the hdf dumps.
how about flipping it with GDAL VRT and gdalwarp? Below I cite an older
email from the GDAL list with a similar problem + solution.
Markus
PS: From gdal mailing list:
On Fri, Jan 16, 2009 at 9:52 PM, Frank Warmerdam wrote:
> Greg Ederer wrote:
>> Hi,
>> I'm running gdal_translate against a VRT file:
>> <VRTDataset rasterXSize="751" rasterYSize="801">
>> <GeoTransform>-20.05, 0.1, 0.0, 40.05, 0.0, -0.1</GeoTransform>
>> <SRS>
>> GEOGCS["WGS 84",
>> DATUM["WGS_1984",
>> SPHEROID["WGS 84",6378137,298.2572235630016,
>> AUTHORITY["EPSG","7030"]],
>> AUTHORITY["EPSG","6326"]],
>> PRIMEM["Greenwich",0],
>> UNIT["degree",0.0174532925199433],
>> AUTHORITY["EPSG","4326"]]
>> </SRS>
>> <VRTRasterBand dataType="Float32" band="1" subClass="VRTRawRasterBand">
>> <SourceFilename relativetoVRT="1">10day_precip.bin.1999121</SourceFilename>
>> <ImageOffset>0</ImageOffset>
>> <PixelOffset>4</PixelOffset>
>> <LineOffset>3004</LineOffset>
>> <ByteOrder>MSB</ByteOrder>
>> <NoDataValue>-999.0</NoDataValue>
>> </VRTRasterBand>
>> </VRTDataset>
>> I just noticed that the resulting GeoTIFF is upside down. Is this a
>> problem with my GeoTransform values? If so, what values would produce the
>> image right side up?
> Greg,
> I don't see any obvious problem with the geotransform values.
> Perhaps the image really is upside on disk. If so, you could flip it as
> it is read by changing your values to
> <ImageOffset>2403200</ImageOffset>
> <LineOffset>-3004</LineOffset>
> Best regards,
