[GRASS-user] Re: WinGrass-6.4.0-1-Setup.exe crash
Dan Connors
dpconnors at ieee.org
Mon Nov 22 22:04:43 EST 2010
Markus Neteler wrote:
> On Mon, Nov 22, 2010 at 1:54 PM, Dan Connors <dpconnors at ieee.org> wrote:
>> I downloaded and installed WinGrass-6.4.0-1-Setup.exe. When I try to run
>> "GRASS 6.4.0 with MSYS" from the desktop, the terminal session starts up
>> fine and several windows open. When I highlight a dataset in the GRASS
>> GIS
>> gui and hit "Start GRASS", I get a popup window "execution failed 'g.proj
>> -p'" and this error stack when I hit "OK" for the popup window. Can you
>> help me fix this problem? Thank you.
> Can you please try with the more recent
> http://grass.osgeo.org/grass64/binary/mswindows/native/WinGRASS-6.4.SVN-r44203-1-Setup.exe
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Markus,
I installed WinGRASS-6.4.SVN-r44203-1-Setup.exe. When I launch Start GRASS,
I now get this error:
Unable to get current geographic extent. Force quiting wxGUI. Please run
manually g.region to fix the problem. Reason:No module called
customtreectrl
Dan
View this message in context: http://osgeo-org.1803224.n2.nabble.com/WinGrass-6-4-0-1-Setup-exe-crash-tp5762566p5765312.html
Sent from the Grass - Users mailing list archive at Nabble.com.
