[GRASS-user] Not possible to display vector data
Monica Buescu
monicabuescu1985 at gmail.com
Tue Nov 23 06:50:50 EST 2010
Greetings
I have a vector map with the following characteristics (v.info)
v.info test01_LU
| Layer: test01_LU |
| Mapset: Regional
| Database: D:\data
| Title:
| Map scale: 1:1
| Map format: native
| Name of creator: monica |
| Organization:
| Source date: Tue Nov 23 11:19:55 2010
| Type of Map: vector (level: 2)
| Number of points: 0 Number of areas: 76832
| Number of lines: 0 Number of islands: 7949
| Number of boundaries: 172475 Number of faces: 0
| Number of centroids: 76816 Number of kernels: 0
| Map is 3D: No
| Number of dblinks: 1
| Projection: Transverse Mercator
| N: 276083.7674 S: -300404.804
| E: 162129.0811 W: -119191.4075
| Digitization threshold: 0
| Comments:
(Tue Nov 23 11:41:42 2010) Command finished (0 sec)
When I try to display it in a Map Window my wxGUI freezes and it gets non
responsive. What might be happen? DO you suggest to "wait"?
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101123/475d3862/attachment.html
