[GRASS-user] Re: Values from multiple raster -
Daniel Victoria daniel.victoria at gmail.com
Tue Nov 23 08:16:39 EST 2010
Ok, I misunderstood your problem. You want the concatenated values,
not just the map of the different crossings. Maybe use r.cross and
then some grep magic in the raster category file
Daniel
On Tue, Nov 23, 2010 at 10:02 AM, Gabriele N. <gis.gn at libero.it> wrote:
> Hy Daniel.
>  I do not think that r.cross can solve the problem.
> With r.cross I could get a concatenation of label:
> For example, with values A = 12 B = 3323 C = 1 the result with the label
> "category 12, category 3323, category 1"
> However, if you know a chance I can prove otherwise.
> As a result, the value of cell in the raster output should be 12332301
> Ciao
> Gabriele
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Values-from-multiple-raster-to-link-together-tp5741032p5766350.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
