[GRASS-user] Memory problems with v.in.ogr
Achim Kisseler
ak7 at jupiter.uni-freiburg.de
Fri Nov 26 07:11:17 EST 2010
My guess:
7GB is a lot.
334611 primitives are many, but not that much,
but:
you got 18 millions vertices! (18459167)
That seems a lot.
Depending on how tangled your lines are, a potential mass of features
can be generated.
Just a guess,
best,
Achim
Am 26.11.2010 03:14, schrieb Pierre Roudier:
> Dear list,
> I am trying to load a pretty big shapefile on GRASS (6Mb +, 211621
> features) using v.in.ogr, but each attempt fails at the 'break
> boundaries'' stage (at 98%!):
> GRASS 7.0.svn (NZTM2000):~> v.in.ogr
> dsn=~/Documents/DATA/LCDB2/ni_nzmg.shp out=ni_lcdb2 --o
> Projection of input dataset and current location appear to match
> Layer: ni_nzmg
> Counting polygons for 211621 features...
> Importing map 211621 features...
> 100%
> Building topology for vector map<ni_lcdb2_tmp at ni>...
> Registering primitives...
> 334611 primitives registered
> 18459167 vertices registered
> Number of nodes: 211681
> Number of primitives: 334611
> Number of points: 0
> Number of lines: 0
> Number of boundaries: 334611
> Number of centroids: 0
> Number of areas: -
> Number of isles: -
> WARNING: Cleaning polygons, result is not guaranteed!
> Break polygons:
> 100%
> 100%
> Remove duplicates:
> 100%
> Break boundaries:
> ERROR: G_calloc: unable to allocate 50 * 8 bytes of memory at
> allocation.c:82
> The shp loads without any problems on QGIS.
> Here is my config:
> GRASS 7.0.svn (NZTM2000):~> g.region -p
> projection: 99 (New Zealand Map Grid)
> zone: 0
> datum: nzgd49
> ellipsoid: international
> north: 6115136.31665518
> south: 6114206.6264583
> west: 2703766.53250003
> east: 2705045.64941879
> nsres: 1.99933376
> ewres: 1.99862019
> rows: 465
> cols: 640
> cells: 297600
> GRASS 7.0.svn (NZTM2000):~> g.version
> GRASS 7.0.svn44411 (2010)
> OS: Opensuse 11.3, with 7Gb RAM.
> Any pointers appreciated,
> Pierre
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
