[GRASS-user] v.rast.stats over a large vector file
Markus Neteler neteler at osgeo.org
Sat Nov 27 12:03:00 EST 2010
On Sat, Nov 27, 2010 at 5:50 PM, Markus Metz
<markus.metz.giswork at googlemail.com> wrote:
> On Sat, Nov 27, 2010 at 5:42 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Sat, Nov 27, 2010 at 5:37 PM,  <razmjooeis at faunalia.co.uk> wrote:
>>> No...same error
>>> /usr/local/grass-6.5.svn/scripts/v.rast.stats2: 350: Syntax error: "("
>>> unexpected
>> The line looks like this:
>> # create array with new column names
>> col=( `cat "$COLNAMETMP" | tr '\n' ' '` )
>> This looks like a bash-ism. In case that /bin/sh isn't bash
>> on Sab's machine but another shell it is likely to fail.
> Hmm. Since you (Markus N) are listed as main author and I merely try
> to promote v.rast.stats2, and my knowledge of scripting is limited to
> bash, do you have a suggestion about how to make this portable to
> non-bash?
I have uploaded an attempt to fix the problem to Addons-SVN.
markusN
