[GRASS-user] Memory problems with v.in.ogr
Pierre Roudier
pierre.roudier at gmail.com
Mon Nov 29 16:11:39 EST 2010
Dear all,
I tried the very same thing on the stable version of GRASS (6.4 RC7 -
which AFAIK is the stable 6.4), on the very same machine.
Unfortunately, I still an error. On the "Break boundaries" state
during the imprt, it is stuck for a while at 4gb RAM used. Then for
some reason the memory consumption becomes much bigger (maximum
actually - 6.2GB+2Gb swap) and the process gets killed.
Any pointers would be much appreciated. Otherwise, maybe I should open
a bug for that?
Cheers,
Pierre
2010/11/28 Pierre Roudier <pierre.roudier at gmail.com>:
> Thanks for your answers. Yes, this is a 64bits OS.
> 2010/11/27 Markus Metz <markus.metz.giswork at googlemail.com>:
>> On Fri, Nov 26, 2010 at 3:14 AM, Pierre Roudier
>> <pierre.roudier at gmail.com> wrote:
>>> Dear list,
>>> I am trying to load a pretty big shapefile on GRASS (6Mb +, 211621
>>> features) using v.in.ogr, but each attempt fails at the 'break
>>> boundaries'' stage (at 98%!):
>>> GRASS 7.0.svn (NZTM2000):~ > v.in.ogr
>>> dsn=~/Documents/DATA/LCDB2/ni_nzmg.shp out=ni_lcdb2 --o
>>> Projection of input dataset and current location appear to match
>>> Layer: ni_nzmg
>>> Counting polygons for 211621 features...
>>> Importing map 211621 features...
>>> 100%
>>> Building topology for vector map <ni_lcdb2_tmp at ni>...
>>> Registering primitives...
>>> 334611 primitives registered
>>> 18459167 vertices registered
>>> Number of nodes: 211681
>>> Number of primitives: 334611
>>> Number of points: 0
>>> Number of lines: 0
>>> Number of boundaries: 334611
>>> Number of centroids: 0
>>> Number of areas: -
>>> Number of isles: -
>>> WARNING: Cleaning polygons, result is not guaranteed!
>>> Break polygons:
>>> 100%
>>> 100%
>>> Remove duplicates:
>>> 100%
>>> Break boundaries:
>>> ERROR: G_calloc: unable to allocate 50 * 8 bytes of memory at
>>> allocation.c:82
>>> The shp loads without any problems on QGIS.
>>> OS: Opensuse 11.3, with 7Gb RAM.
>> Is this a 64 bit OS?
>> I have previously successfully imported larger shapefiles, more than
>> double in size: >400,000 areas, >40 million vertices, peak memory
>> consumption was close to 4GB. The import of your shapefile would
>> approximately require about 2GB of memory, which should not be a
>> problem with 7GB available, as long as it's all 64 bit and not 32 bit.
>> Markus M
