[GRASS-user] Loading IPCC GCMs into GRASS from NetCDF
Thomas, Timothy (IFPRI) T.S.Thomas at cgiar.org
Tue Nov 30 14:32:24 EST 2010
I am having a problem loading the IPCC GCMs into GRASS.  You can find
one of them at
http://www.ipcc-data.org/cgi-bin/downl/ar4_nc/pr/BCM2_SRA1B_pr_c30b.tar.
They are in NetCDF format.  The problem, I believe, is two-fold.  First,
the grid is an irregular shape, 512 by 512 cells for the whole earth.
Second, it does not appear to have degrees as bounds.  It may also have
a third difficulty that I have not yet encountered, and that is how to
get the desired band (which is the fourth one).  Has anyone else tried
loading these and could recommend a command or series of commands?
Thanks!
   Tim
Timothy S. Thomas
Research Fellow, International Food Policy Research Institute (IFPRI)
2033 K St. NW, Washington, DC 20006-1002 (Room 5035)
t.s.thomas at cgiar.org         www.ifpri.org
(w) +1-202-862-4605         (f) +1-202-467-4439
skype: timothy.s.thomas
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101130/a26f7c20/attachment.html
